| Big O |
01-31-2010 07:46 PM |
Help! Grounding Brake wire.
I was trying to ground the brake wire on my power acoustik ptid 8970NRB so I could watch movies on my breaks at work, but when i connected the brake wire to the wire i used for the ground and turned the key forward, my deck didnt turn on. I then disconnected the ground from the brake wire, turned the key again and still nothing. I checked in my manual and it said to check fuses and connections, and if that didnt work then hit the reset button on the front of the deck. I did all those things and it still doesnt work! Is my deck fried?! Or what should I do? I bought the deck last December from amazon. Would they even replace the deck? The deck doesnt smell fried.
