installed these yesterday
6 Attachment(s)
looks alot better then stock i also installed led bulbs in the turn signal housings
nice, how is the light pattern?
Originally Posted by Twip
(Post 597829)
You wont need load resistors if you got the flasher..
(Post 597878)
I have a white blazer, and am planning on getting the same lights, but with the black interior. Those halos look great. Glad to hear they look good and work well. Thanks for the information.
Originally Posted by 95jimmy_slt
(Post 597914)
i know the flasher relay is supposed to fix the hyper flashing but is it also supposed to cure the dash indicator lights also? cuz i have heard that sometimes it wont cure the turn signal indicator lights staying on and sometimes it will and the only lights that are led are the 3157 bulbs and i have heard that you will need one of those resistors behind every led you install for the second gens but im just not sure.
(Post 597987)
the LED flasher I got for my jimmy made the dash lights flash normally.
well good news i solved my led turn signal problem you will need a led compatible flasher relay along with load balancing resistors. after installing my dash indicators are no longer giving me a bulb out indication and they flash normal maybe just a fraction of a second faster then stock! side note: make sure you mount the resistors to metal and away from any wiring or plastic as they do get hot.
| All times are GMT -5. The time now is 07:11 PM. |
