led window switch lights
Old Dec 29, 2011 | 04:58 PM
jayj99jimmy's Avatar
jayj99jimmy is on a distinguished road
Default led window switch lights
i know ive gotten help with this already. before i buy led's, can anyone tell me what size LED's i need to do my power window switches, 4wd buttons, rear defrost, hvac, rear wiper switches, and headlight switch?
if you know what size LED i need for any of these please let me know. im having trouble figuring out what sizes/models will work. i have the 2 door jimmy 1999, so my driver window switch has 1 bulb, the lock button has an even smaller bulb (both have a base that is twist lock using a flat head to lock and unlock it in the hole) the rear defrost button needs to be soldered, i will probably just put any ol led in there because it is not restricted space wise. the power mirror switch probably doesnt matter much either. so i realy just need to know what bulb will fit in the stock base on the power window switch/lock switch. and are the bulbs for the rear wiper switch and the 4wd buttons all soldered? i will be heading to a wrecking yard again to take everything apart and try to figure it out.
any bulb size help is appreciated. i already ordered my dash bulbs thanks to help on here and soon as i get my lamp bases in the mail ill finish getting those in. i tried soldering the bulbs into the factory bases and its too ghetto for me, so im buying new bases for my leds there.
thanks
Old Apr 21, 2012 | 11:19 PM
JRP22's Avatar
JRP22 is on a distinguished road
did you ever figure out what size bulb goes in the window switch? mine blew
Old Apr 22, 2012 | 12:48 AM
Thogert's Avatar
The link is in my sig.
shotnva777
Nov 29, 2011 10:02 PM
96jimmyslt4x4
Sep 21, 2011 09:14 AM
96jimmyslt4x4
May 29, 2011 03:55 PM
GolfClapperX
Jun 5, 2009 03:48 PM
EuroGoldLS
May 18, 2009 01:18 PM
