-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Lighting options (https://blazerforum.com/forum/lighting-electrical-52/lighting-options-67982/)
sstealthx4747 02-14-2012 01:42 PM
Lighting options
I am absolutley a newb when it comes to distance lights and trucks. Im not a newb to forums and tryed searching multiple times. I am looking for distance lights that are bright that i can mount to the front pillars on the truck that will give me good sight on the beach at night. Max 6.5" diameter. I dont know any other light brands other then Hella and they dont make one small enough. I can wire them in myself but if anyone has any helpful tips they are always appreciated. Any input would be great. Thank you.
Thogert 02-14-2012 02:05 PM
I have 4 KC daylighters on my light bar, they are about 6.5" OD and they are 'long range' lights. (Also known as a pencil beam.) They will light up things at +500'.
Or you can go with the cheapo's. It's really up to you, I'd check out the KC site and see what's avalible.
By the way, how are you going to mount them on the A-pillars?
sstealthx4747 02-15-2012 06:12 AM
Aren't pencil beams more like spot lights? Or will they give me a semi wide view? Remember im only looking to do 2 not 4. And whatever mounting hardware the light comess with im going to sink a bolt through the bottom of it and drill and bolt it to the A pillar.
Thogert 02-15-2012 11:50 AM
Yeah, pencil beams are spot lights. You can go with driving lights, which will give you a wide beam that also goes out far, but they are usually more expensive.
Some brands I know of are: hella, piaa, kc, lightforce, and the cheap ones you can find on ebay, amazon, or at your local parts store.
You can also consider led off road lights. They are really expensive, but put out an amazing amount of light for how much power they draw. If you want to look into these I'd check out Rigid Lighting.
pj5454302 02-15-2012 06:41 PM
Ok, heres what ya do. Go to harbor freight get these lights
6" Off-Road Light System
And order 5000k
35 or 55 watt
h3 bulb
from here
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
sstealthx4747 02-15-2012 10:59 PM
Thanks guys. I will definitely take those into consideration.
sstealthx4747 02-17-2012 10:32 AM
I think im going to go with 2 PIAA 520 ATF lights for a long range but wide view.. Anyone have any objections or other recommendations?
Thogert 02-17-2012 11:26 AM
Sounds good, get some pics of them once you get them on if you can.
sstealthx4747 02-18-2012 10:03 AM
i definitely will. Thanks for your help.
