lights
Bought new off road lights Friday from Harbor freight and installed them tonight. Finally got everything bolted on and wired and nothing. I checked the fuse and it's OK all of the grounds are attached the only thing I didn't do was ground the switch itself. Will this cause the lights to not work?
Any help would be appreciated |
How do you have them wired directly from the battery fuse switch and lights or are you splicing into anything
from the switch one wire to battery with a 20 amp blade fuse. then one to lights with a jumper wire in between and both lights grounded individually. Im wondering if my grounds there are no good.
a test light is your friend !!
switch should only need ground if it has a light in it itself run a temporary ground back from each light to the battery , will test your ground |
Chances are you don't have a good ground. You should really look into using a relay.
Thanks for the help. I'll try a different ground when I get home. That's what I was thinking was the issue.
rexmburns I've never ran a relay on any before so I don't know how to go about wiring one into the system. |
| All times are GMT -5. The time now is 02:35 PM. |
