-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   low beams dont work (https://blazerforum.com/forum/lighting-electrical-52/low-beams-dont-work-53140/)
THAGOLDENB Dec 23, 2010 04:57 PM
low beams dont work
I have a 1979 Chevy blazer and my low beams don't work. Only the high beams will come on when i press the dimmer switch and then to switch back to low beam theres no light. Dimmer switch is also new by the way. Has anybody else had this problem? If so any input would be great!
swartlkk Dec 23, 2010 05:31 PM
Have you tested for power on the tan wire at the headlights? If you do not have power there, then the next thing to do is test continuity to the dimmer switch. I'm betting that there is a break in the wire from the dimmer switch to the driver side headlight.
THAGOLDENB Dec 23, 2010 07:18 PM
Checking for power
I have not yet tested for power on the tan wire. How do I exactly test to see if I have power? Do I turn headlights on to low beam and check by using a volt meter on the tan wire? And do I check both sides?
swartlkk Dec 23, 2010 07:41 PM
Yes. Headlights on low beam and use a multimeter. The wire goes from the dimmer switch to the driver side headlight then over to the passenger side headlight. You do not need to test at both locations since neither light works, but you can test it.
THAGOLDENB Dec 23, 2010 08:31 PM
What is going on???
I was outside checking for power. I noticed there are 6 wires total (3 pairs: 2 black, 2 green and 2 tan wires) going into the headlight. The green and tan were both getting power. The weird thing is that now only the drivers side headlight will work on HIGH and LOW beam but the passenger side does not turn on at all anymore.. As before both the headlights turned on but only in high beam and not in low.
old skool luvr Dec 23, 2010 09:56 PM
have you checked the actual HL switch yet?
your problem sounds similar to the one i had with my '78 FS. i had dropped in a newer coloum (with the dimmer switch & wiper controls mounted to the coloum), and a few months after that i started having pulsing issues with the LB, and eventually they would just shut off after a few minutes.
whole mess of hair pulling, and it turned out to be a failing HL switch.
swartlkk Dec 24, 2010 09:55 AM
The wiring you mentioned was on the driver side headlight, correct? That's where it should be. One of each of the green & tan wires runs over to the passenger side headlight. The green wire should have power when the high beams are on and the tan wire when the low beams are on.
It sounds almost like you have a problem in where the wires connect in at the driver side headlight.
THAGOLDENB Dec 25, 2010 09:52 AM
Figured out the problem
I pushed in the wires that connect in at the headlights and headlights came on! The connections feel sort of loose tho. Can i fix this problem?
old skool luvr Dec 25, 2010 11:12 AM
if it's just a loose conection, then use a small standard screwdriver, and gently spread out the female connectors from the back of the plugs.
if you feel you can't get in there with a small enough screwdriver, then use one of those dental pic/hook tools. be casreful though, you don't want to bend them out too far (i've seen the old ones break off).
you could also just go to a wreckers & cut them off a parts truck (provided you find ones in good enough condition). you can also try looking @ one of the larger parts suppliers. not exactly sure what any of the Auto Zone's or Pepboy's carry down there, but i know that CTC & Advance up here carry alot of the more common plugs (GM ftw!).
try NAPA as well, as i've seen a few @ my local one.
GL.
