Massive Electrical Issue
Old Dec 8, 2015 | 12:54 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Originally Posted by swartlkk
Dash lights being on makes me think that the ignition switch may be fried inside. You can check out the link in my signature for more information on the ignition switch. They typically fail due to burnt connections that do not pass current, but you may have a situation where the contacts have fused together.
Old Dec 8, 2015 | 02:23 PM
WV01Blazer's Avatar
WV01Blazer is on a distinguished road
Fuse in, service engine light on, alt whine, key out of ignition, driver door open
Hooked up my scanner/code reader and got the following:
LIVE DATA
DTC_CNI 0
FUELSYS1 0L
FUELSYS2 0L
LOAD_PCI (%) 0.0
ETC (F) 46
SHRTF1 (%) 0.0
LONGF1 (%) 0.0
SHRTFI2 (%) 0.0
LONGFI2 (%) 0.0
MAP (inHg) 28.9
RPM (/min) 0
VSS (mph) 0
SPARKADV (*) 0
IAT (*F) 54
MAF (lb/min) 0.000
TP (%) 0.0
AIR_STAT OFF
02SLOC B1S12 -- B2S1 ---
02 B1S1 (v) 11.5
SHRTFTB1S1 (%) 0.0
02B1S2 (V) 0.280
02B2S1 (V) 0.095
SHRIFIB2S1 (%) 0.0
OBDSUP OBDII
There were no codes
This show anything?
Old Dec 8, 2015 | 04:43 PM
WV01Blazer's Avatar
What the actual you-know-what ...
Decided to run one last test with scanner before it got dark. Inserted the IGN B fuse ... and no noise from the alternator. Thinking battery has drained again even with the one fuse removed I check battery connections, tight, open door and interior lights go on as normal, no service engine light, things look normal.
Insert key, turn to 'on', everything behaving normal. Fuel pump priming, dash lights as should be so I decide to try a start. Normal cranking but no start. Try again, no start. Try again, no start. Yes, there is gas in tank.
Figure f-it for the night and close up hood when I notice I failed to reconnect the wire to the whatever it is small cannister attached to intake manifold directly in front of throttle body after replacing alternator so I hook it back up, try again to start, cranks but still nothing.
Think I smell gas under hood? Maybe it won't start with that wire removed and is flooded?
On the up side this has to be the easiest alternator to replace.
On the down side the battery in my truck went bad so new one on the way. The battery on my phone died while talking to my parts guy too.
Thanks for the information on the switch, was Bing-ing more info about that when I decided to run my last test of the day.
So we'll see what happens in the morning.
Old Dec 8, 2015 | 04:58 PM
CWBDDSPC's Avatar
Well hey, that's awesome if you don't have to dig into the switch!!
Who uses Bing though??!
Old Dec 8, 2015 | 07:12 PM
WV01Blazer's Avatar
What-the-actual-you-know-what continued.
Just walked through my kitchen only to see all the exterior lights on the Blazer lit up. Whine from the back of the alternator, yada, yada, yada.
Tried to see if it would start, cranked and cranked but no fire. Def smell gas under the hood.
Pulled the IGN B fuse for the night n charging up the new battery.
Old Dec 16, 2015 | 09:01 PM
hurleyii's Avatar
hurleyii is on a distinguished road
Pull the engine bay fuse box and see what the back of your box looks like just found mine corroded to **** and broke off during removal it was so bad. 50 and 60 amp fuse power supply or outlet for ABS and interior power
Old Dec 17, 2015 | 09:05 AM
WV01Blazer's Avatar
Thanls for the tip. I've let the Blazer set since my last post, half because I have other things to do and half because my truck was having problems too. Truck problems ez fix so did those before Blazer.
I was thinking the same thing about looking 'inside' the fuse box. I remember a year ago I had been working on something and had the box open so I could remove a fuse when a flash rain hit and the open box got wet, I had some goofy things happening right after that that cleared up when the box apparantly dried out. Couldn't hurt to have a look to see if anything is going on in there.
I'm still taking advice!
Old Dec 18, 2015 | 04:00 PM
hurleyii's Avatar
Check the bottom side where all the wires plug in
Old Jan 10, 2016 | 11:38 AM
WV01Blazer's Avatar
Can anyone tell me where the BCM is located?
Old Jan 11, 2016 | 05:21 PM
hurleyii's Avatar
I think BCM is under the center of the dash behind and a little below the ash tray .
DetailersDomain
Detailing
Jun 19, 2012 09:22 PM
s10blazer20
Jan 27, 2011 04:38 PM
dcshoes1
Aug 6, 2009 01:20 AM
Tippman7641
May 24, 2008 02:50 AM
avorg
Mar 15, 2008 11:52 PM
