my power locks stopped working 98 blazer
well one day i lost power to my locks inside its kinda a on going problem i check to see if it was the fuse the fuse looked good, so i was stumped so i just changed the door panel i thought maybe that was the problem and that wasnt the problem now they work when they want to but then they will go out for days then kick back in. now what could be the problem. by the way i have a 98 4d blazer
Originally Posted by bobby099
(Post 538728)
...so i just changed the door panel...
Have you tried to roll the passenger door glass down from the passenger side switch when the driver side switch doesn't work? Have a 2k and I had/have the same issue. Mine is rain water corroding the contact in the switch. I just work it a little and it starts to work again. The thing doesn't sit still long enough to clean the contacts the correct way. |
the power windows work just not the locks. i still havent found the problem
Has to be a loose connection somewhere if they work sometimes and not other times, have you tried to operate the power locks from the passenger side door, if you have keyless entry, does that lock the doors?
if the fuse looks good, I would start by making 100% sure the connection at the switch is secure and not dirty, clean the contacts, next would be making sure the fuse is proper seated in the slot. find the fuse, and play around with the switch and as you do, wiggle and move around the fuse. |
| All times are GMT -5. The time now is 04:44 AM. |
