Need fuel pump testing help. 02 blazer
My fuel pump stopped running today so i put a new one in,but it still doesn't run.
Can anybody tell me the right way to check the relay under the hood and the location of the fuel pump fuse? I swapped the relay with the identical horn relay and that didn't help. I also need to know how to test the wiring at the pump since I can't find a diagram. I do know the gray wire is hot for 2 seconds when the key is turned on. So far by searching the internet i need to check that stuff,grounds and the oil pressure sending unit also. |
| All times are GMT -5. The time now is 11:12 AM. |
