Need help
Old Jul 2, 2017 | 12:03 AM
Travis Nelson's Avatar
Travis Nelson is on a distinguished road
Default Need help
I just bought a 02 blazer 2 door. Im having a problem with the map lights, dome lights, and the back hatch is not working. the back latch has no power like the lights. and i am having a problem with the garage door opener as well it dosent have any power as well any one have an idea? iv been through all the fuses and replaced all the ones that were bad
Old Jul 2, 2017 | 02:40 PM
Rusty Nuts's Avatar
Welcome to the forum. How many and which fuses, if you remember, were blown? Have you re-checked them? A short can cause a new fuse to blow as soon as the circuit gets power.
Old Jul 4, 2017 | 09:51 PM
Thank you for the welcom .it was just one a little 3 amp. it ran the door locks and the power mirrors. I have checked the fuses again and I have pulled the deal that holds the map lights to check the connections. everting seems to be in order. I did change the bulbs to see if that changed anything but still nothing.
Old Jul 5, 2017 | 02:09 PM
Rusty Nuts's Avatar
I would investigate that locks and mirrors circuits for the problem. Strange as it sounds, I've read threads here from members who've repaired a broken power mirror and the interior lights started working again.
Old Jul 7, 2017 | 08:45 PM
ok ill pull out the test light and start chasing this stuff down. any words of advice for me?
Old Jul 7, 2017 | 09:11 PM
Rusty Nuts's Avatar
I would start by checking all the buttons and switches for what doesn't work and causes that 3 amp fuse to blow.
stuntz
May 28, 2017 10:05 AM
1hugeblazer
Feb 21, 2011 06:05 PM
maximashift
Nov 17, 2009 09:36 AM
maximashift
Nov 17, 2009 09:33 AM
