Need a sealed battery
I need a sealed battery for my dual battery setup. What do you guys recommend. It needs to be some what small though. I have a yellow top that is a little too big. It is roughly 10x8x8 thats leaving room for terminals. It is going to run all of my accessories (6 driving lights, amps, cb, winch, and whatever else I decide to hook up).
optium-i assume you already had one by the yellow top
agm batteries -absorbed glass mat http://www.concordebattery.com/ |
yes i have an optima as my main battery. Im also looking to keep it in the $200 range. I didnt see any prices in that link but by the looks of it they are expensive.
just curious, where are you putting the second battery and how do you plan on hooking it up, Battery isolator? also would love to see some pics after its installed!
yeah i was looking at kenetic's. Will this one be ok http://www.onlinecarstereo.com/CarAu...ik_KHC800.aspx. or should I go with a higher wattage.
Originally Posted by Ryanmatt135
(Post 299888)
nice, never thought of putting one there.
so, will an 800 watt kinetik battery work fine or will I need a 1400w
Go with the biggest you can fit. If you can squeeze the 1400, do it.
