-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   need to verify wiring diagram info (https://blazerforum.com/forum/lighting-electrical-52/need-verify-wiring-diagram-info-73743/)
jrrybrwn Sep 13, 2012 10:54 PM
95 blazer 4.3 vin w with cpi injector.
trying to fix no injector pulse problem. need to verify what i have found is correct so i can proceed.
Fuse 10 ecm/ign feeds the following:
injector- pink wire- a on connector
crank sensor- pink wire- c on connector
control module- pink wire- a on connector
vcm C3 Gray? pin 18
and injector ground vcm C2 Red? dark blue wire- pin 3
hopefully someone can verify this for me so i can get this thing fixed finally.
thanks
