-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   New to forum need help (https://blazerforum.com/forum/lighting-electrical-52/new-forum-need-help-100990/)
Tony123 Jan 25, 2020 07:35 AM
2002 LS 4X4
When I bought the truck I noticed that when I put it in gear it would automatically lock the doors. It just stopped
I used to have running lights
can't get it into program mode for key fob
sometimes the lights don't come on on overhead compartment when key is off the push-button ones
my alarm used to work when I lock the door I still have a blinking light but no sound from the horn
I checked all fuses but not the relays
Truck has 150,000 miles
also have a clunking sound when I make a left turn or go over a bump
thanks for any help
LesMyer Jan 25, 2020 12:48 PM
Sounds like related to the BCM, but not to imply that it is defective and should be replaced. Needs someone technically adept to diagnose per factory information.
christine_208 Jan 26, 2020 03:10 PM
Your clucking could be a bad ball joint.
christine_208 Jan 26, 2020 03:11 PM
Since you are new, "BCM" = Body Control Module. It is one of the small electronic "brains" that runs our Blazers. You might have some bad connections in the wiring harness.
