-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Outside Mirrors Not Working (https://blazerforum.com/forum/lighting-electrical-52/outside-mirrors-not-working-107294/)
Gene H Apr 21, 2025 03:34 PM
Does anyone have any troubleshooting suggestions for inoperable mirrors on both doors of the vehicle? The power remote control is not working.
swartlkk Apr 21, 2025 05:34 PM
Could you please give us your vehicle details (year, make, model, and any options that might be pertinent)?
Gene H Apr 22, 2025 06:30 PM
Yes, 2001 Blazer LS.
swartlkk Apr 22, 2025 07:30 PM
THIS POST has the 99+ mirror schematics in it that should help with some testing. I'll attach the relevant diagram below:
https://blazerforum.com/forum/attach..._schematic.gif
I'm assuming that you have already checked the MIR/LKS fuse. Since you only have a complaint of inoperative mirrors and not a power lock issue as well, the fuse is likely okay.
Per the diagram, you should have +12V to the orange wire (pin G at the power mirror switch connector) and a good ground on the black wire (pin B at the power mirror switch connector). Does the switch illuminate at night when the lights are on? If not, this could be an indicator of a bad ground to the switch.
