-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   power window relays 1987 s10 blazer 2dr (https://blazerforum.com/forum/lighting-electrical-52/power-window-relays-1987-s10-blazer-2dr-69070/)
knitter0217 Mar 16, 2012 08:08 PM
Are there relays? If so where are they and how can I tell if they're bad? Both windows won't move
chris015 Mar 16, 2012 08:16 PM
No relays. Just a ac relay and fuel pump relay.
If both are dead,Its either the main window switch(which is on the drivers side) or a broken wire between the door and the cab. Pop the little rubber boots loose and check all the wiring. Mine was a solid black wire that was broken.
knitter0217 Mar 17, 2012 08:00 AM
K thanks. I was planning on pulling the door panel off today
