-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Problem with rear glass release (https://blazerforum.com/forum/lighting-electrical-52/problem-rear-glass-release-81406/)
Colby9255 08-31-2013 10:28 AM
On my 95 blazer, the rear button was working fine, till the other day it wouldnt release, no click at all. the dash switched doesnt work either. ive checked all my fuses, changed everything in the hatch, and still no click.
what the hell is it! lol
cleburne red 08-31-2013 10:11 PM
If you've checked the fuses, are you getting power to the little actuator in the tailgate? You said you've replaced everything, so I'm guessing you replaced the actuator thing itself? If it's new, and you're getting power to it, it should work
WitchingHour 09-01-2013 03:11 AM
The actuator has a little plastic arm on it, which is prone to breakage. Worth looking into.
Colby9255 09-01-2013 05:54 AM
i have a parts truck that robbed the actuator off of, i guess its possible that ones cooked too, and the little blue arm is still good
OfoSho84 09-07-2013 04:22 PM
I just replaced the actuator with a brand new one checked fuses and bought a new fob and none of it works for my 96. have no idea and finding wiring diagrams is a pain.
Alphadog 11-05-2013 11:14 AM
does your prndl indicator work on your dash? if not it could be your park/neutral safety switch. The vehicle has to be in park for the latch to release
jtorlando25 11-05-2013 01:00 PM
Do your power door locks and mirrors still work?
Jasongr81 11-05-2013 02:46 PM
If your blue plaxtic pc breaks just drill a hole and put a couple zip ties in there. Worked great for me.
