-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Question about CB radio and amp (https://blazerforum.com/forum/lighting-electrical-52/question-about-cb-radio-amp-70493/)
IanD 05-05-2012 07:49 PM
Hey everyone, I have a quick question about a CB radio and PA speaker.
Does it matter what size amp I hook the speaker / CB Radio up to? I have an 800 watt amp that I'm running my subwoofer off of and was wondering if I could run a 65watt speaker and a CB radio off of this same amp, or would it blow the speaker?
Thanks in advanced.
Ian
neo71665 05-05-2012 08:34 PM
No where close to being compatible parts.
krunk357 05-05-2012 09:21 PM
that is an understatement
the amp for cb radios is a high-power linear amplifier and it is used to boost the send and receive power of the radio not the sound level of the speaker
neo71665 05-06-2012 02:51 AM
Footwarmers don't boost receive very well (cleanly) so I wouldn't say they boost that at all. Main function is pretty much to boost the transmission of the radio.
IanD 05-06-2012 08:38 AM
I don't plan on using the CB radio as a radio, just as a PA system for the truck, which will be directly wired to the PA speaker. Still a no?
IanD 05-06-2012 08:39 AM
Basically, I just want to wire the Amp to the CB/Speaker for power.
bigrigger7220 05-06-2012 09:59 AM
if i'm understanding correctly, your wanting to use the ext speaker jack from cb, wired to amp than to speaker right?
neo71665 05-06-2012 11:11 AM
Could be done but would have more time and trouble in it than a $20 pa speaker is worth.
IanD 05-07-2012 03:02 PM
So what do you suggest that I do? Just wire it directly to the battery(CB / Speaker)?
neo71665 05-07-2012 03:22 PM
PA Horn SPEAKER w/ Plug & Wire - 5 inch for CB / Ham Radio:Amazon:Automotive
