question regarding headlight mod
Old Sep 27, 2011 | 06:59 PM
priesman64's Avatar
priesman64 is on a distinguished road
Default question regarding headlight mod
I've done some searching for the headlight mod where all lights are on when hi beams are on and i'm wondering if it is possible to this mod without cutting wires? I'm a member on duramaxforum.com and this is the thread to the mod for those trucks.
How To: Headlight All On Mod - Chevy and GMC Duramax Diesel Forum
Is this possible to do with our trucks?
Old Sep 27, 2011 | 11:05 PM
rriddle3's Avatar
Have you used the Search function for thread titles containing "quad beam mod"? It pulls up 7 threads that may help.
Old Sep 27, 2011 | 11:46 PM
gojorg's Avatar
I know that Painless wiring does a kit for that, you got to get the right one if your drl's are the high or the low.
Jorge
Old Sep 28, 2011 | 08:52 AM
98blazin's Avatar
98blazin is on a distinguished road
i did it a couple weeks ago on my 98 blazer. (DRL are high beam at 50% power)
at first, i just grounded the yellow wire on the driver side to the core support.
it works but it messes with you AHL and DRL. i wanted to keep both.
so, i redid it with a simple relay. took me about 15 mins and my headlights are operating like stock but with the flip of a switch i have quad beams.
Old Sep 28, 2011 | 11:33 AM
priesman64's Avatar
I dont want to run a seperate switch and if the headlights are not near as bright as they are now then I don't want to do this mod.
Old Sep 28, 2011 | 03:47 PM
98blazin's Avatar
i think you dont understand.
if your truck have low beam DRL, i cant help you.
if your truck have high beam DRL, you just have to ground the yellow wire on the driver side.
but, doing this will make your low beams to be DRL.
your AHL will be disabled, because low beams will always be on.
a simple switch and a relay will cure this problem, maintaining the stock functions on DRL and AHL, and will allow you during the night to flip a switch and have quad beams.
Old Sep 28, 2011 | 06:16 PM
priesman64's Avatar
I guess I did understand you wrong.. I dont know what my DRL are right now, I put HIDs in them the day I got my blazer. For some reason I do remember my DRL being my high beam though but my buddy also had an 01 blazer so I might be thinking of his.
Old Feb 28, 2012 | 12:35 AM
midnightmuddin's Avatar
midnightmuddin is on a distinguished road
Exclamation Quad Beam Mod Using Relays.. & How To Convert Polarity For Switched (-) High Beam
See attached photo.. i put together a diagram i use on all my installs.. Also in the diagram, how to switch polarity from (-) to + using a relay for those of you who have a (-) switched wire to activate high beams. (I assume should be most if not all of the blazers, s10s, jimmys, bravads, and sonomas) Hope this helps everyone! This is a great and safe way to wire it up if you plan on wiring in all hids!
Last edited by midnightmuddin; Feb 28, 2012 at 12:40 AM. Reason: Fixed link to image..
melliferal
Mar 29, 2014 11:18 AM
Woober
Jul 10, 2009 07:23 PM
Cmurda
May 20, 2009 08:59 PM
2klt
May 16, 2009 01:09 PM
wesmagyar
Feb 16, 2008 12:19 PM
