| Jeff53 |
Sep 28, 2022 11:22 AM |
Replacing reading lamp bulbs
I need new bulbs in the reading lamps of my 1996 Jimmy. I currently have the console out of the vehicle. How do you get the lens off of the lamps go change the bulb? I have a 2006 Silverado and there is a small notch in the lens where you can pry it out. On the Jimmy, there is no notch and when I try to pry the lens with a small screwdriver, it seems like it's glued to the reflector. I don't want to break anything, so I thought I'd check here. I've seen instructions for the 98 and up (they have the notch), but I can't find anything on the 95-97. I don't see an easy way to replace them from the rear, either. Thanks.
