Small wire fire on firewall
The fusible link blows with current not voltage. Yes I suppose its possible that a damaged link blew with normal current but not as likely in an engine thats turned off unless there is a fault. But possible, yes. I was betting on a shorted alternator diode but the problem did not repeat. The reason I suggested rodents originally is because the truck had just been sitting after a prior successful start. Yes the charging current is higher if the battery is not fully charged to 12.6V. Not sure if the charging current will be high enough to blow the fuse in the initial charge after starting, never measured that first minute or so.
George
George
truck started right away. It stayed on continuously. No gas coming out the top (so must have been flooded earlier). Then I realized that I didn’t diagnose much except that 20A was not enough to run the D and E circuits together.
then I realized you said something in your last response to check and I re-read it. So I check the voltage across the battery and it read between 11.50 and 11.60. I thought that that was weird because earlier today it was reading 11.93. So I shut it off and check the voltage across the battery and it was 11.73.
something was pulling voltage instead of the battery being charged. Then it hit me. The alternator wasn’t charging and the engine was slowly draining to fire the cylinders. I began to loosen the negative battery cable and the truck instantly shut off. I opened the inline fuse holder for the alternator-junction box wire and the fuse was burned.
tentative diagnosis: alternator’s cr@p
but why?
will it be as simple as new alternator and new fusible link?
Depends. IF the same voltage was at the back of the alternator and you can get the battery to take a charge with a wall charger - get over 13V charging and charge to 12.6v then you are probably correct. If the alternator is hosed I may have been correct and you may have had a shorted diode which connects the battery to ground. You can of course remove the alternator and have it tested. Same with the battery.
George.
George.
George.
George.
I don’t have a wall charger, so I will just hook up some jumper cables and charge with another vehicle.
George.
George.
the alternator was tested this morning and found to be good. It was charging 14.4-14.7 volts. I am at a loss to explain this.
You need to have the battery tested as well because it can have a shorted cell which can pull the alternator output down. Then make sure the battery is charge to 12.6 V hook everything back up and start the truck. Then measure the voltage at the positive battery post and then at those alternator output stud. If those voltages are different then you have a wiring problem. If those voltages are the same and 13 or 14 V then you’re good. If those voltages are the same but 11 and change then you have a field excitation problem and we have to solve that
George
George
George
George
charged the battery for awhile and brought it to store and it tested good (12.35V, so a little low, but no shorter cells).
tomorrow, I will reconnect both, charge battery a little more and restart.
George
George
started immediately. Immediately checking the battery voltage showed 13.1 V, then I checked the positive cable to the alternator and would get strange numbers bouncing around but which would always end up as “1L” or something weird (kinda like “wire not continuous” when you check the for continuity). If I changed the scale on the multimeter from 20 (where I normally check) to 200 or 1000, I would get a steady number (I don’t remember the numbers) for the alternator.
I shut the truck off and thought about it. Then restarted it and went to check everything again. This time the battery read 11.76V. I check the alternator and got “1L” again then immediately checked the 20A fuse on that line and it was blown again. I shut it down and now the battery is reading 12.10V
the fusible length (7 feet of it in case I have to do it multiple times)... was due to arrive today via fedex but shows delayed until tomorrow. That is why I tried again with my fuses.
I also did not want to keep checking since I noticed oil smoking near the exhaust..... it never ends with these money pits!
George
George
truck started up immediately. Voltages measured with the negative on the chassis ground and the positive on the battery positive post (14.36 V steady) and the positive on the positive terminal of the alternator (14.87 V steady).
After running for a few minutes, I shut the truck off. I went to check the fusible link. It was warm to the touch, but not hot. The adjacent wires in line were cold to the touch.
thoughts?
