speedo not working running out of options
I have a 2000 chevy blazer 2wd the speedometer and odometer are not working ive replaced the cluster and the vss because i was told it would be either of those. Now that i have tried both options and its still not working im turning here so any info would be greatly appreciated
thinking maybe it could be a wire coming from the vss to the computer
i had this problem on my GMC Sierra,i replaced the cluster and the vss i sent it into the shop because i was fedd up with it after about 3 months and a speeding ticket.. The Mechanic told me it was a Solenoid on the transmission. not sure how honest he was tho. Hope this helps.
does your cruise control work? If not, put ohmmeter on pins 29,30
https://blazerforum.com/forum/attach...iew_pcm_c1-jpg |
yes the cruise control does work everything works just like it should. besides the speedometer and the odometer.
ductapeguy how much did they charge you for that? |
3 Attachment(s)
Originally Posted by michaelmoodyblazer
(Post 513648)
yes the cruise control does work* everything works just like it should. besides the speedometer and the odometer.
Check PCM C4 {black conn} pin 4 drk grn through c203 pin E11 to cluster conn A4. Dark green all the way. NOTE: If you have aftermarket radio check to see someone didnt screw with the drk grn wire in radio harness {no idea why it goes there} see the simple diagram |
it was around 210 dollars. but i honestly think the canadian tire mechanic ripped me off.
Is your speedo working now?
| All times are GMT -5. The time now is 07:39 AM. |
