-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   SRS Code B0036 Isolated and Corrected (https://blazerforum.com/forum/lighting-electrical-52/srs-code-b0036-isolated-corrected-103724/)
mr.vls Aug 3, 2021 02:00 PM
My 2000 GMC Jimmy SRS light has been off/on for the last 4 months. I did not have a scanner the could read the SRS codes so I purchased one from Harbor Freight. The scanner found SRS Code B0036. My factory service manual indicated that this was a possible short to ground or a faulty impact sensor. I assumed it was an impact sensor and pulled a right/left sensor from a junkyard. The SRS light would still light intermittently after I replaced the sensors. I decided to simplify installing the sensors by installing 1/4-20 threaded inserts and used stainless steel truss head screws to mount the impact sensors. I got serious about trouble shooting the fault IAW the service manual. I checked all the wiring for continuity from the drivers side connector to the passenger side connector. I checked the wiring from the C109 (6 way connector) to the drivers side connector. (4 Pin). I checked the ohm readings from the drivers side (Pins A & C) to the passenger side impact sensor and the readings were 988 Ohms. When I attempted to read the complete circuit for C109 pins A & B, I would either get no continuity or high ohm readings. I made up two jumpers to bypass the drivers side impact sensor by jumping pins A & B and pins C & D, This would allow the the circuit to be complete without going through the drivers side impact sensor. Once I did that the SRS light no long stayed on after start up. Therefore I knew I did not have an SDM problem or a wiring/connector problem. I pulled another drivers side impact sensor at the junkyard and checked pins A & B, C & D for resistance and had 0 Ohms.. The original and 1st junkyard sensor was either measuring open or high ohm readings across the same pins. Once I installed the sensor and turned the key on the SRS light flashed 7 times and stayed off. (Correct operation) The original sensor had an internal short and the 1st junkyard sensor was bad from the get go.
christine_208 Aug 3, 2021 02:36 PM
Great writeup.
I'm looking at possibly another bad SRS sensor going bad on my Blazer. I've wondered if the odds of getting a bad sensor from a wrecking yard will be going up.
What was the model number of the HB code reader? Can it also do the ABS bleed?
mr.vls Aug 3, 2021 03:34 PM
HF Model Zurich ZR13. If you go to pull a sensor from the junkyard bring a multi-meter with you so you can check the resistance across the pins . Drivers side: (4 Pin) Y-Y = 0 ohms, B-B = 0 ohms, Y-B = open., Passenger side: Y-B = 988 approximate as it is a 1K resistor. My original and junkyard passenger side both measured 988 ohms.
mr.vls Aug 3, 2021 03:37 PM
I am not sure about the ABS bleed. HF has a link to the PDF manual. The cover has ABS listed but I am not sure what it can or cannot due. I believe it only reads ABS codes. Nothing in the manual ref. ABS bleed.
