Starting problem!
Old Jul 16, 2012 | 09:50 AM
Chumba87's Avatar
Chumba87 is on a distinguished road
Default Starting problem!
Ok for the past week I've been rebuilding my gf 2.8l motor in her 87 s10 blazer! Finally finished after a couple hours each day! I repaired the wiring harness where there were some old wires! Got the motor in and everything hooked up and it won't start! The starter has 12 v constant but the little wire doesn't get any power when u turn it over... I swapped the relay and still nothing. We tryed jumping it and nothing! I'm stumped!
Old Jul 16, 2012 | 10:14 AM
Droidster's Avatar
Droidster is on a distinguished road
do a bench test of the starter first
double check your grounds, loose, cracked wires connectors
Old Jul 16, 2012 | 10:50 AM
Chumba87's Avatar
Ya if I jump it from the big terminal to the little one it kicks the bendix out but Im not getting power to the little wire when u turn the ignition!
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
mickey2001
Mar 13, 2006 11:51 AM
ghassell
Feb 6, 2006 09:51 PM
blazin97
Jul 9, 2005 03:32 AM
