Sypder Halo Projector Lights
Hello all,
I am new to the Forum. I have been on forums like this before with different types of vehicles i have had. I am assuming that this one is run by the people that ran the one from Dodgeforum. Anyway. I just installed the lights into my blazer and they work great. I am assuming that the 2 wires that are coming up from the bottom of the light are for the halo that is there. I am just curious. were do i wire them into? One would assume that I would just splice into the other wires that are right there for the low beam bulb and just use that to power and ground that halo. will this work and is this what I should do? |
Originally Posted by NE2000Blazer
(Post 422774)
Hello all,
I am new to the Forum. I have been on forums like this before with different types of vehicles i have had. I am assuming that this one is run by the people that ran the one from Dodgeforum. Anyway. I just installed the lights into my blazer and they work great. I am assuming that the 2 wires that are coming up from the bottom of the light are for the halo that is there. I am just curious. were do i wire them into? One would assume that I would just splice into the other wires that are right there for the low beam bulb and just use that to power and ground that halo. will this work and is this what I should do? u can run them also into drl as well |
Drl? Can I just splice em into the bulb wires
(Post 422993)
| All times are GMT -5. The time now is 11:31 PM. |
