Windshield wipers intermittent issue
Old 05-25-2018, 09:25 AM
slowpoke's Avatar
slowpoke is on a distinguished road
Default Windshield wipers intermittent issue
'03 with pulse wipers. Occasionally the wipers will not shut off in response to the switch- they default to low speed constant operation mode. I can get them to go off if I stop and restart the engine, thereby killing power to the wiper circuit. After that, the wipers behave, usually for several uses, but eventually they go thru the above sequence.
Since diagnosis requires the malfunction to be occurring, and killing the ignition restores normal function, I'm never in a position to troubleshoot when the problem happens, as I'm typically on the road. I suspect the circuit board on the wiper motor, but can't rule out a switch problem. Anyone out there ever run into this?
Old 05-25-2018, 11:48 AM
chevyriders's Avatar
https://blazerforum.com/forum/tech-a...r-motor-36236/
My guess would be the circuit board on the wiper motor. Above is a link to a great walkthrough on how to repair them. I did it on my jimmy and it took less than an hour, cost me nothing, and fixed my issue
Old 05-25-2018, 02:53 PM
slowpoke's Avatar
Thanks for the info- I'll try it!
Old 05-25-2018, 05:12 PM
N. Jensen's Avatar
I went thru this several years ago.
I resoldered some of the cold solder joints that were open and it helped for a few months. (Maybe I didn't do the greatest job at it?)
Anywho, I ended up just ordering a new pulse board from Amazon...about 8-9 bucks, if I recall. Has worked like new since!
Old 05-25-2018, 09:27 PM
blazen_red_4x4 is on a distinguished road
I am fighting the same issue and am ready to just buy a new board... I've tried several used ones from the salvage yard (I work there so they're easy to come by :P ), even a couple low mileage ones, they've all had their quirks from staying on to missing speeds, and I've tried resoldering a couple of them and they still had issues. I've went as far as replacing the motor unit as well, AND the switch on the column (actually the main reason for that replacement was to install one with legible lettering on it lol) and I still have intermittent issues.
Old 05-26-2018, 07:45 AM
slowpoke's Avatar
Thanks to all who responded. I'll try the soldering since it costs nothing. When that fails, I'll buy a new board. BTW, a good source of automotive parts is www.rockauto.com.
Old 06-09-2018, 01:22 PM
slowpoke's Avatar
Just got to this puppy today. In the meantime, I came across this: http://my.cardone.com/techdocs/PT%2040-0005.pdf. Since my issue is exactly as this bulletin describes, I cleaned the two contacts of old caked grease and, for good measure, straightened them slightly to get 1 1/8" inches (where they spec 1"). Time will tell whether this solves the issue.
Old 06-15-2018, 02:25 PM
slowpoke's Avatar
Update- since doing this, the wipers have behaved just fine. If that changes, I'll post back.
Old 06-18-2018, 01:59 PM
Glad to hear they are working again!
4x4blazerguy
14
05-03-2012 10:53 PM
ryanarmstrong
05-10-2010 10:46 PM
renee48742
10-17-2009 04:45 PM
05blazer
10-19-2008 07:16 PM
nslide10
11-29-2005 03:22 PM
Quick Reply: Windshield wipers intermittent issue
