-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Temp gauge stuck beyond normal limits (https://blazerforum.com/forum/lighting-electrical-52/temp-gauge-stuck-beyond-normal-limits-80417/)
lockwoodjace Jul 13, 2013 09:31 PM
2 Attachment(s)
I dont know how to fix this so any help would be awesome... It is like that when the car is on or off.
Twip Jul 13, 2013 10:55 PM
gauge is bad. see if you can find someone that works on that sort of thing. the motor on the back of the gauge has gone bad. most of the time gauge places have a price to do all the gauges. but you can call around.
good luck.
Thogert Jul 14, 2013 01:48 AM
There is also a very small possibility that the needle just came loose and slid down.
BMWDr Jul 14, 2013 02:52 AM
If your handy with a soldering iron you can rebuild it yourself. You can get the stepper motors in a kit form on ebay with the newer upgraded motors and new illumination bulbs for @ $30.
chris015 Jul 14, 2013 11:09 AM
check the connections to the temp sensor first. a bad ground can do this too. Ive had it happen a few times.
newguy Jul 14, 2013 12:03 PM
Mine has done that when I diconnect the battery, after driving it a bit it fixes itself
