Turn signal blinks fast...sometimes
2001 LT 4x4 4 door.
Sometimes the turn signal clicks fast. I recall in years past that when a bulb burned out, this happened, but such is not the case here. At least not from what I can tell. Flasher maybe? It happens in both positions, and I just checked to see if it happened with the hazards on and it didn't. So, single signal it happens, then stops if I turn the hazards on. |
You could have a corroded connection in one of the bulb sockets causing an intermittent connection mimicking a bulb failure at times.
good call. I'll check them out.
my flasher relay comes on and off for no reason,turnsignal/hasard working properly.it just tick´s when it likes it,changed relay but same procidier.just wonder what can make it get current? great forum by the way
| All times are GMT -5. The time now is 09:50 AM. |
