-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   What does fuse 13 power on a 95? (https://blazerforum.com/forum/lighting-electrical-52/what-does-fuse-13-power-95-a-82161/)
bigdaddykane93 Oct 16, 2013 06:32 PM
What does fuse number 13 titled RDO BATT power on a 95? just so you know fuse 11 is the radio fuse. anyone know?
Thogert Oct 17, 2013 09:16 PM
RDO BATT should be supplying a constant power source for the radio's memory functions. It should be hot even when the truck is off.
bigdaddykane93 Oct 18, 2013 12:33 PM
so how come when i pull out fuse 13 the radio still holds the pre set stations?
Thogert Oct 18, 2013 01:59 PM
That's a good question. My kenwood keeps the stations when I pull the harness out, but not other settings. So maybe they have a small battery to keep some things. If so, I believe the rad batt supplies the main source of power for the internal amp, whereas the other one only triggers it to power on. IDK Just two separate circuits I guess.
bigdaddykane93 Oct 22, 2013 07:46 PM
since not really sure what its for 100 percent maybe its better to leave the fuse out because its always drawing amps...
