-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   White dome and map lights! (https://blazerforum.com/forum/lighting-electrical-52/white-dome-map-lights-69925/)
96chevblazer 04-14-2012 06:58 PM
Hey guys I got a 97 blazer with a sunroof and I want to replace the ugly yellowish bulb with white LED's in the map, dome lights, and rear light. Now having the sunroof makes the lights different than most other blazers as I don't have the swivel map lights for the squarish dome light. I don't have a picture of the map lights but they are the push button ones, like the ones here
95-97 BLAZER JIMMY DOME LIGHT INFO CENTER W/HL 96 !!! | eBay
And the dome light is an oval one.
Also I will replace the rear hatch light.
So I need to know what # of light each are and if someone could find me white LED's that will fit directly that'd be great, Thanks
Gkolo1 10-30-2012 01:23 PM
How do you remove the covers to get at the bulbs ?
I have the same set up in a 97
Thogert 10-30-2012 01:53 PM
You should be able to (very carefully) use a flathead screwdriver and pry on the edge and they should pop off.
Side note: They should be T10 bulbs.
Gkolo1 10-30-2012 03:03 PM
Ok thanks, For some reason the front map/dome lights dont work, But the useless little cargo light in the back works when you open the doors.
No fried fuses.
247monster 10-30-2012 04:45 PM
i just put all blue leds in my dome, dash, cargo and gear light (the light that shows what gear your in for blazers with the shifter on the floor lol) i love it man its a cool custom look and alot better then coloring light bulbs with sharpies lol =)
