why do gauges get wacked when battery put on
Old Aug 4, 2014 | 08:24 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default why do gauges get wacked when battery put on
i was always curious of this, everytime i do something that requires the battery to get disconnected and then when it comes time to put it back on it goes on fine then i look at my gauges and theyre all out of wack. by this i mean the rpm and mph are pinned to the right and the temp gauge is usually just hanging, i have to keep taping the positive terminal onto the battery and hope it shocks it back to normal
and reason why this does this? is this normal?
Old Aug 5, 2014 | 01:22 PM
TrevT1's Avatar
TrevT1 is on a distinguished road
Mine doesn't do that, and that doesn't sound normal.
Old Aug 5, 2014 | 01:30 PM
newguy's Avatar
Mine does that, dont keep sparking your battery, your gonna pop afuse or something. For me ,I just drive it and it fixes itself
Old Aug 5, 2014 | 01:55 PM
er0ck273's Avatar
havent tried driving to fix it, gonna clean the throttle body later today and will most likely try driving it before i try anything else
Old Aug 5, 2014 | 03:23 PM
newguy's Avatar
Some of my gauges will be maxed out, speedo temp. But everytime once i got up to cruising speed they popped right back
Old Aug 5, 2014 | 05:15 PM
er0ck273's Avatar
today after i got done cleaning the TB, i reconnected the battery, the only one out of place was the temp gauge the needle was drooping, just tapped the cluster and it went back, the way things work haha
Old Aug 5, 2014 | 06:01 PM
newguy's Avatar
Cool, I never really worried about it much
Old Dec 15, 2014 | 05:14 PM
Possum 6991's Avatar
Possum 6991 is on a distinguished road
My tach & speedometer pegged when I replaced the alternator on my 2000 Blazer LS. The tach reset itself after I started the engine but the speedometer would not. I was able to reset/push the needle back to the left side by sliding a short piece of string trimmer line through and around the trip reset button. It took a little patients but it is working fine now.
Old Dec 15, 2014 | 06:21 PM
rexazz2's Avatar
should always connect the positive first when installing battery with the key in the off position
remove the negative first when removing the battery
wonder if that has anything to do with it
Old Dec 16, 2014 | 09:44 PM
odat's Avatar
From what i've read REXAZZ2 is on the right track - always unhook the neg first the the pos, when reinstalling the pos first then the neg - Key off for both disconect and reinstall of battery - surges the computer and other componets if done any other way - It can also surge the remote start and make it turn over while your trying to hook up the battery
sacnfox85
Sep 27, 2014 11:00 AM
Ricschulze
Jun 18, 2013 09:48 PM
builder125
May 20, 2013 06:51 PM
blazinloud
Jan 5, 2011 10:29 AM
Blazer_Xtreme
Jul 30, 2006 03:54 AM
