wiring harness seems to be stuck?
I've recently been trying to replace the passenger door speaker. to get to the speaker I've had to remove the door pannel, but in order to do that you have to disconnect the power window and lock buttons. now there are two harnesses there, one small one (which came out easily), and a lager one. The larger one will not budge. I've tried every trick I know (which have worked on the driver side door harnesses) to get it off. do you think it could be broken in some way? has anyone else had this problem?
phxjosh
Oct 30, 2013 10:03 AM
trapper_canada
Aug 15, 2005 11:33 PM
