1999 Ford Taurus Sway bar links
I took the Taurus into the shop b/c it needed some stuff done. I don't work on cars very often, but I think I can fix a problem they found. While fixing the other thing I had them do they found both rear sway bar links were broken. While searching the interent for the part I came across rockauto.com. Is the Stabilizer Bar Link just another name for the sway bar b/c the parts look the same.
Same part, different names. Just make sure to get them for the correct body, IIRC sedans and wagons differed from each other here and there with suspension stuff, but I don't see the cross eyed catfish Taurus/Sables (96-99) too often anymore, normally the next generation up ultraman ones (2000-07)
| All times are GMT -5. The time now is 02:20 AM. |
