Fm transmitter
I'd like to build a stereo fm transmitter to send my mixes out to the car and listen... What's the best circuit for the best hi fi sound ? Anything out there that is cheap, that can compete with the quality the local radio station is transmitting, but just on a smaller scale... probably around half a watt or so ?
Any tips ? thanks....... |
Originally Posted by JinjerSO
(Post 690194)
Any tips ? thanks....... I had a mp3 player/fm transmitter 15 years ago. It's pretty old technology. Modern car stereos have Mp3 and Bluetooth built in. |
I remember when high definition meant you had tin foil on your antenna. Not useful, but funny now.
Guys, someone edited my previous comment, I did not leave any references there! Probably you got a hacker-spammer. Or the moderator has edited ... In general, if I do not bear any responsibility!
Lesmyer, yes! But but I'm considering a model GoGroove FM transmitter So, Has your transmitter been running for 15 years? Wow Rusty Nuts, аortunately, I did not find those times because I did not need to have any transmitters or antennas ) |
(Post 690275)
On the topic at hand, low power FM Transmitters are very low power transmitters (typically less than 1 µW) that are good for a hundred feet or so in unobstructed flat land. Looks like you want to go considerably farther than that as you stated 0.5W... The FCC (in the US) and IC (in Canada) both have published limits for personal unlicensed broadcasting on the FM bands. Best to do some research before you get yourself in trouble. |
https://cimg3.ibsrv.net/gimg/blazerf...58eacfd765.png
I am sorry, I can wrong, but as you see this two word are marked as links on Amazon... Do not they show up like that? I just warn you that you did not have any questions. I'm sure that the modification works at the highest level. And now about the theme of a topic. Do you think my transmitter is too powerful? That is because of this there may be a problem? I'm a little dumbfounded Ou... Something wrong and I cant receive picture.....Anyway, in my first comment words "stereo" and "circuit" are markedhttps://cimg3.ibsrv.net/gimg/blazerf...183ec90941.png like links to Amazon. |
(Post 690275)
So, Has your transmitter been running for 15 years? Wow The links get inserted automatically by the forum. Apparently some advertising $$$ to help maintain the forum. |
Originally Posted by Lesmyer
(Post 690292)
(Post 690282)
Well....I heard you guys. Thank you
If you’re still looking for a solution, you may want to strongly consider replacing the whole radio. You can get a new one that does Bluetooth, USB, SD, and AUX for under $100 from a good brand (with install parts). You’ll have far more wattage available which actually cuts down on audio distortion. A website like Crutchfield will make sure you get the proper dash adapter, wiring harness, and antenna adapter. If you’re going through the trouble, you may as well just upgrade. Just my two cents. Good luck! |
