Help me choose a welder!
So I have been looking into buying a welder ever since I started the restoration of my Chevelle. I would like to have a welder of my own in my garage that I can use for the projects that I have.
My father has a large 220V MIG that is currently setup for 045 to 065 wire with the torch liner and drive rollers. To change over to the 024 wire would be a pain only because we would have to switch back and forth all of the time depending on what we were doing. So larger stuff is no problem with his welder and I like the idea of the portability and flexibility of a 110V welder. Only need a 110V-20A circuit and plug to be able to use the welder!
The welders I am considering include:
Lincoln Power MIG 140C - $670 w/ cart
Miller Millermatic 140 - $680 w/ cart
I was also considering the Hobart Handler 140 - $560 w/ cart...
I'm really leaning towards the Lincoln simply due to the cost of replacement parts and accessories. I also like the ground clamp and wire feeder design of the Lincoln much better than the Miller, but do not have a good feel for the design of the Hobart wire feeder. However, the Hobart doesn't have infinite amperage control like the Miller and Lincoln. Due to the fact that I may be welding up inconsistent sheetmetal thicknesses (due to rust, etc), I really feel I want/need the infinite control.
The Lincoln also comes with more parts in the box, including all of the accessories for flux core welding which the Miller does not come with, but has available.
I still have to buy a welding helmet with either of them...
Thoughts/Opinions???
Very nice! The prices I listed above are from an eBay Store which I have heard good things about in some of the sheetmetal and welding forums I have been wading through. Most of those guys don't use a welder this small though.
I like the Millermatic 212, but I know that on is way out of your price range at $1700.
If I wanted a small welder, I'd go with the 140 with Auto-Set. It should be perfect for auto-body. Itscosts slightlymore than the 140 but its much easier to use.
ORIGINAL: EuroGoldLS
It isn't that $1700 is out of my price range as money really isn't the factor here and rarely is when it comes to tools for my garage. I want portability. Something that I can plug into a 110V wall outlet and go.
