High beams only...help!
2006 Honda civic. All of a sudden I have no regular beam lights...only high beams.Turn signals work. Please help..Thanks.
so your drivin around like a jack ass? LOL try turning the high beams off? j/k! I dont know
2 Attachment(s)
There looks to be quite a bit going on in the schematics for the headlights on those things. Maybe the low beam relay has quit...
I would start at the Relay as Kyle said. I may be wrong, but the high beam and low beam relay are most likely the same p/n, just swap them over and see if you get your lowbeams back, if the highbeams don't work after that you know for sure that it was the relay.
This is a friends car...can you tell me where the relays are located? Engine compartment or dash...thanks.
hey, did you guys see that....someone came on here called NHoccutegirl and quoted me then took it down....WTF!? I did a search and nothing! someones messin with me.
This isn't facebook
Originally Posted by BresBlazy
(Post 396418)
thank you! LOL I was like whats goin on here!?
