Rancho Steering Stablizer
Anybody know What model Rancho steering stablizer I should use for my
70 K5 Also I'm upgrading to 37" x 14.50 Tires Will I need a duall stablizer set-up or can I get by with a single.... Thanks |
id go with a dual. they say anything bigger then a 35 you should go with a dual set up. i dont know if one brand is really better then the other. if at all possible try to get one where it doesnt have the two shocks right on top of each other right in the middle of the axle. if you are going to offroad this truck you can damage them and screw your steering up. i been running duals for about 8 years and have replaced that bottom shock about 3 times
Originally Posted by abig84
(Post 513750)
that must be annoying Might as well weld a plate over them =P |
Yea
I'v read that over 35's should have duals but wanted the hear it from someone. I'll look for a side by side set-up.... Thanks |
