Replaced Camshaft in Tecumseh 12.5
Old Jan 10, 2018 | 04:22 PM
mr.vls's Avatar
Default Replaced Camshaft in Tecumseh 12.5
My MTD riding lawn mower became almost impossible to crank. Researching the internet I found out that the most likely cause was the compression release pin has worn down on the camshaft. Since new parts for Tecumseh engines are limited I took a chance on a used camshaft off of Ebay. I had already removed the old camshaft from the engine and when I received the used camshaft I measured the compression release pin height above the camshaft. The used camshaft pin was just a little bit taller. I installed the camshaft reinstalled the engine onto the mower and the engine cranks without any problem and is running great. I found an article on the internet how to fabricate a compression release pin from piano wire and I am going give it a go for future use.
Bybsurfr32
Jun 2, 2019 04:00 AM
chevyguy1993
Feb 14, 2014 10:51 AM
rob2129us
Dec 19, 2007 10:03 AM
murfthesurf4
Nov 26, 2007 11:00 AM
88blackzcand95blazer
Jan 26, 2007 04:36 PM
