Reverse Brake Bleeding Tool?
Old Mar 9, 2023 | 02:22 PM
Default Reverse Brake Bleeding Tool?
Hi all,
I like to think I'm pretty up on the tools we might use for working on our vehicles but I never knew about the Reverse Bleeding Tools. Have any of you used these on your Blazers? Are they worth it?
https://www.brakebleeder.com/product...brake-bleeder/
Old Mar 9, 2023 | 02:30 PM
I haven't used that one specifically, but I have used various vacuum and pressure bleeders. The one that works best for me is the same fluid evacuator I use for oil changes, etc. I just put a small tube on it with a short length of hose on the break bleeder.
Old Mar 9, 2023 | 05:50 PM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
Not me. I'd recommend one of two different options. Either a MightyVac or something similar to this https://www.autozone.com/test-scan-a...ke+bleeder+kit. The MightyVac has other uses, like testing your vacuum system.
Old Mar 9, 2023 | 11:42 PM
So the thing that is new to me is that these "reverse brake bleeders" push new fluid in at the caliper towards the master cylinder!
Old Mar 10, 2023 | 07:42 AM
Yeah, I never heard of that before, then you'll need to get the fluid out of the master cylinder as you push it up there. It sounds to me like one of those solutions that we don't have a problem for.
Groundunit
Jan 2, 2018 12:42 PM
247monster
Jul 26, 2012 02:17 PM
atvwarrior
May 20, 2011 05:32 AM
cochran07
Mar 7, 2011 04:36 PM
