Reverse Brake Bleeding Tool?
Hi all,
I like to think I'm pretty up on the tools we might use for working on our vehicles but I never knew about the Reverse Bleeding Tools. Have any of you used these on your Blazers? Are they worth it? https://www.brakebleeder.com/product...brake-bleeder/ |
I haven't used that one specifically, but I have used various vacuum and pressure bleeders. The one that works best for me is the same fluid evacuator I use for oil changes, etc. I just put a small tube on it with a short length of hose on the break bleeder.
Not me. I'd recommend one of two different options. Either a MightyVac or something similar to this https://www.autozone.com/test-scan-a...ke+bleeder+kit. The MightyVac has other uses, like testing your vacuum system.
Originally Posted by Walleye Hunter
(Post 747679)
(Post 747683)
So the thing that is new to me is that these "reverse brake bleeders" push new fluid in at the caliper towards the master cylinder!
| All times are GMT -5. The time now is 11:24 PM. |
