-   The Lounge (https://blazerforum.com/forum/lounge-5/)
-   -   Spark plug gap& type. (https://blazerforum.com/forum/lounge-5/spark-plug-gap-type-94671/)
mrbizznitch May 21, 2017 07:07 AM
Anybody had any dealings with putting spark plug gaps at 40 instead of 60 thousands? Regular plugs, double platinum, iridium, E3's, spiltfires ??????
rriddle3 May 21, 2017 08:22 AM
In what engine and why?
chevyriders May 25, 2017 12:06 PM
The only reason ive heard of people closing their gaps is if they're running nitrous... Other than that, or possibly if you're running super high compression- I don't think there is any legitimate reason to do that.
TonyZR2 Jul 16, 2018 10:00 AM
If you have a bad wire and the spark is taking a differen't path........ couldn't you temporarily shorten that plugs gap to get spark(until you get new wires)?
:icon_denk:
error_401 Jul 18, 2018 03:38 AM
If the spark jumps from the wire shorting the gap would IMHO not be a remedy.
Insulation tape would do the job on a cable, even a piece of rubber hose that you slide over the damaged part. A piece of a paper clip and a yard of electrical tape did the job once a rodent ate one of my ignition cables.
I've used both for emergency repairs which stayed on the truck for several weeks before changing cables.
Most important: use the correct type of cable. Resistor or none and correct plugs.
I've found that spark gaps in production cars can be way out of specs and still work flawless. Good measure to set them at the manufacturers spec. They have been testing that for a long time to figure the best in safe operations and economy.
TonyZR2 Jul 18, 2018 05:57 AM
Love the rubber hose idea.
