sunroof open for downpour
To make this short snd sweet, my girl left her sunroof open overnight during a pretty decent downpour...she has cloth seats and cloth on her door panels etc. Whats the best method to dry it out and get thr musty smell out ? Besides keeping windows open when its sunny out
If you can get a dehumidifier
put inside with the cord out the door Run on high |
Originally Posted by rexazz2
(Post 635194)
wife and I went out for dinner
sunroof was tilted only Sky was clear when we went in the restaurant and clear when we came back out.It was one of those places you cannot see outside I hopped in and did the WTF bail back out I would have swore that someone had poured a bucket of water in on my seat The car was on just the right angle that that it came in mostly on the drivers seat Later talking to a friend they asked us if we got caught in the thunder storm :icon_doh: if you keep the car closed up the dehumidifier will try to pull moisture from the air BTW if you dont have a wet vac to try and remove the worst of the water , go to one of those car washes with outdoor vacs and suck up as much as possible |
a shop vac works pretty good too if you have a lot of water in it, suck up the pools first before running the dehumidifier. i used to detail cars as my first job and a few other methods we would use especially during the winter is let the car run with the heat on floor. just crack the window so the moisture can get out.
fans work just as well but might take a little longer |
[QUOTE=abig84;635289]a shop vac works pretty good too if you have a lot of water in it, suck up the pools first before running the dehumidifier. i used to detail cars as my first job and a few other methods we would use especially during the winter is let the car run with the heat on floor. just crack the window so the moisture can get out.
fans work just as well but might take a little longer[/QUOTE as of now, she said its mostly spot dried, but i will still run the shop vac on anything that might have still been wet. will definitely do the heat idea i never thought of that, luckily she has rubber mats that line her floors but i guess when i see her in a few hours well see how bad it is haha |
