The Thunderbird
okay i have NO idea where to post this but i just remembered, im having a problem with the thunderbird
it is a 1990, with a non s/c 3.8
heres my problem, i found oil in the throttle body, and intake tubing, only near the tb...................
any ideas?
any ideas?
wow that was quick, haha
i need to consult my friends dad, and see when he has time to help me check it out, cause i limited tools and im not going in blind because i have no idea what i would be doing
Just pull the PCV valve out of the valve cover, and see if you can hear it rattling when you shake it. Its a 5 dollar part and should be changed every 20,000 or so and with tune ups. There is a hose that goes from it up to the throttlebody for the vented pressure to re-enter the motor. The part is probably shaped like an "L" and is about 2 inches by one inch with a hose coming off it. It just pulls out of the valve cover.
