Welcome spring
for those of us with the spare underneath, check the air pressure in your spare,
exercise and grease your cable |
Do everything that winter prevented you from doing, lube up suspension components, door hinges, any fluid changes that you neglected.
Ahhh no more tire chains, spin outs and trying to sleep in a tractor trailer with the engine running...
I got my complete 1840 watt system installed in the big rig, so its time to roll down the windows and shake the earth a little. Booyah!!! Rotated the tires on the Silverado, cleaned and polished the chrome, adjusted the air pressures back up to 45psi (from 30 in winter), changed the oil and filter, lubed the door hinges and locks, lubed everything underneath, vacummed and steamed the backseat area real good (2 year old twins) checked brakes (will need front brakes soon), and shes ready for another summer of spanking on the local kids here in Camrose Alberta. The blazer still sits in the garage... |
| All times are GMT -5. The time now is 12:32 AM. |
