Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
3 inch drop suggestions
Old Jan 29, 2012 | 10:37 PM
1998blazerLS's Avatar
1998blazerLS is on a distinguished road
Default 3 inch drop suggestions
I'm planning on dropping my 98 LS 4dr 2wd, I've looked around and I plan on doing 3" drop blocks in the back, and 3" lowering springs for the front. I plan on using this Ground Force kit 9921 - Ground Force - Lowering Kit 3" / 3" At StylinTrucks.com
It says it fits the 2dr model, but doesn't the 4dr use the same kit?
Also, I would like to know what problems any of you have encountered installing a similar kit (rusted out bolts, broken bolts, etc.) so I can be ready for the "unexpected". I should be ordering the kit in the next couple of weeks, so I wanted to find out as much as possible about lowering. I know how to do it, and I will be helped by a mechanic friend of mine. Just wanted to pick everyone's brain.
Any input would be appreciated, thanks.
Old Jan 31, 2012 | 09:57 PM
I'm ordering this ground force kit either friday or saturday, unless I find a few people who have had bad luck with (I've been thumbing through the forum and have not found anything specifically bad. I hope to get it installed during the Mardi Gras holidays in a couple of weeks (if it comes in in time), if not then I'll have to wait a couple more weeks. HOPEfully it comes in for Mardi Gras.
Old Feb 2, 2012 | 11:36 PM
Just ordered my drop kit, should be in by the end of next week...hopefully
Old Feb 5, 2012 | 02:23 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
Keep us informed. I'm in the market for lowering my 04 but was thinking new spindles in the front vs the springs. But I would be interested in your results.
Old Feb 6, 2012 | 01:54 PM
if you look around, people say that you get the same drop either way, but spindles are way more expensive
Old Feb 8, 2012 | 02:55 PM
drop kit is coming in tomorrow, pretty effin excited
Old Feb 8, 2012 | 09:25 PM
Alignman's Avatar
Alignman is on a distinguished road
Spindles do cost a few more bucks, lower control arms with dropped pockets work well too. Spindles keep the ball joints at the right angles as well as tie rods at proper angles. Ball joints last longer and maintain full alignment adjustability and keep the tie rods at proper angles to prevent bump steer. Lower center of gravity while gaining a better roll center are also benefits of spindles. Thats the best way to go.
Praise the Lowered!
Old Feb 9, 2012 | 10:41 AM
^^^what he said
Old Feb 23, 2012 | 05:47 PM
dropped it this passed monday
before
after
and some extras
just the front dropped
Old Feb 25, 2012 | 11:30 PM
Antbankz's Avatar
Antbankz is on a distinguished road
curious...do you have to swap for different shocks when using that kit or are you still using ur old ones? how long did the work take? p.s. looks good
