3' lowerins springs???
are these a bad idea.. i went to a local shop and they said that my front wheels would bened in if i had these on the front.. wth is w/ that? im just looking for a 3/3' drop.. can anyone help w/ some advice??? ASAP!!!!!!!!!!!!!!
RE: 3' lowerins springs???
3inch lowering springs will work fine but you will have to have an allignment done right after because yes your tires will be off because changing the springs to shorter ones change how the tire sits.
I would recommend 1" lower springs and 2" drop spindles. That will keep your steering geomerty and alignment in check. :D
