-   Lowering Tech (https://blazerforum.com/forum/lowering-tech-45/)
-   -   4x4 Frame Swap to 2X4 (https://blazerforum.com/forum/lowering-tech-45/4x4-frame-swap-2x4-23935/)
dubb_05 10-10-2008 10:40 AM
I was wondering if a frame from any s10's or a 4dr would be the same.. I have a 2dr 4x4 blazer and want to swap frames to a 2x4 frame. Can I use a s10 frame or a 4dr frame? Or does it have to be a 2dr 2x4 frame?
swartlkk 10-10-2008 10:49 AM
RE: 4x4 Frame Swap to 2X4
You would definitely have to use a 2dr frame and it has to be from a non-ZR2 (yes they were offered in 2wd as well in the later years [&o]).
That is a whole lot of cost just to switch your truck from 4wd to 2wd...
packofqtips 10-10-2008 12:55 PM
you could take a 2wd pickup frame and use the front clip and have that grafted onto your blazer frame otherwise you will need a 2wd blazer frame
95_4door 10-10-2008 07:09 PM
What about just taking the 4wd components out and swapping in a 2wd trans and driveshaft?
It would be cheaper and easier in the long run.
packofqtips 10-10-2008 09:17 PM
the suspensions are very different and if you remove the front half shafts the hubs come apart
95_4door 10-11-2008 05:16 PM
If you leave the outboard stub, you will be fine
