95 4x4 lowering ?'s
so ive come to the conclusion i want to lower my 95. i know i need to get some blocks for that back and i can just to a torsion bar drop in the front. is there anything bad that will happen by doing this? and how would i go about dropping that back. i have no clue on this. any info would be helpfull.
Drop blocks will come with new u-bolts. And you are going to need new drop shocks as well.
yah i know about all that. just was is there to putting the blocks on the back??
can have it done in no time. put it on jack stands, use the jack to support the rear end, undo the u bolts and jack up the rear until your blocks fit, tighten, put the blazer back on the ground and re-tighten. if doin 3 or more inches might want to get the angled blocks to keep your pinion angle good. good luck
| All times are GMT -5. The time now is 08:05 AM. |
