any 98 up lowered blazers?
Let see pics and tell us what kind of kit and how many inches you dropped it!
Am I the only one?
try searching for packofqtips' blazer. i believe that will be along the lines that you're looking for.
Blazer Forum - Chevy Blazer Forums - View Profile: packofqtips |
Yes blazers.b.kewl his is stupid clean, but I'm lookin for the 98's up 4door lowered,
1 Attachment(s)
Attachment 31828
2000 2Dr 4x4 Blazer 3"/3" Belltech keys in the front and 3" blocks in the rear. Street Performance shocks 245/50/16 tires. 3/3 is about the lowest a 4WD blazer can go without damaging the CVs in the front or having to do heavy fabrication. |
2 Attachment(s)
This is my 96 with an 01 front conversion dropped 3/4.
https://blazerforum.com/forum/attach...ine=1364525460 https://blazerforum.com/forum/attach...ine=1364525460 |
2001 4dr right now its at two inch front and rear. Soon to be 3.5/3.0. Front spindles with two inch springs minus a quarter inch spacer. In the back Im changing two inch blocks for two inch springs and about one inch blocks. The block dimentions are aproximate, as the Chevy lean needs to be rectifyed.
1 Attachment(s)
Here's my 97 with 3" ground force springs and blocks with Toxic brand drop shocks from summit and 205/65/r15 tires, setting it 5" lower than stock height
https://blazerforum.com/forum/attach...ine=1366049053 |
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1375335900
Leaf removed/drop spindles and springs Horrible ride |
my old 95 was spindle dropped with blocks in the back. i think it was a 2"/3". rode hard, but still turned heads mostly because it was a work truck.
