Bagging a 4 door
Bagging a 4 door
for those interested i will keep this thread updated with the bagging of the rear of my 4 door blazer
the front is the same as any other s-series vehicle
Basicly what i am doing is a forward facing 4 link and my rear floor is being rasied up enough for a body drop
Next winter a SFBD will be done to my blazer
I had to ditch the 4 door gas tank and sway bar. I'm going with a 2 door gas tank and no sway bar.
you could use a fuel cell if wanted.
also my frame is being dehumped. so the frame will be flat from front to back.
All this work is being done by pyscho customs in Cranston RI i'll have pics as soon as i can
Heres my blazer before it went into the shop
RE: Bagging a 4 door
Are you going to do a cantilever setup in the rear for lift??? Also i would suggest a watts link and then with your four link have them mount the bars under the axle for the forward bars therefore saving the rear floor as much as possible. That is what I am going to do to the rear of mine, just giving you a suggestion in case you want to save your floor in the rear. Also to keep in mind is that blazer's don't need a king kong notch either which alot of people think they need to do, the only reason for one is if your going 22's or bigger but in that case you can always do a underslung frame which will save your floor more then doing a huge notch. Just a few things for you in case you needed some extra info, but being a fellow minitrucker I am sure you allready have it all figured out!!! Good luck and I can't wait to see it layin frame!!!
sounds sweet
already going with a small notch and the floor is being raised up enough to clear my rims when i do a sfbd next winter
so no pics yet but right now my frame has been cut straight and the 4 link is ready to be mocked up and installed tommorow
its done!!! driving it home tomorrow!! so excited i'll get plenty of pics and stuff for the pic ******
If the character limit lets you even post
Lookin forward to it though!
what character limit?
Where are the pics at??? I disappear for two months and there's no new pics LOL!!! Can't wait to see it man!!
