Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Do 2" lowering blocks need to be angled?
Old Dec 21, 2025 | 11:46 AM
wmblalock86's Avatar
wmblalock86 is on a distinguished road
Default Do 2" lowering blocks need to be angled?
It's been a while and I can't remember, do 2" lowering blocks for a 2002 Blazer, 2WD, 4DR, need to be angled?
I know 3"+ need to be to adjust the pinion angle, but I can't remember about 2".
Old Dec 24, 2025 | 02:46 PM
Bass_Surfer's Avatar
Bass_Surfer will become famous soon enough
Talking
The biggest consideration is that the pinion and output shaft be at the same angle.
If you move the pinion to 5° positive (up) - then the output shaft has to be 5° negative (down).
Understanding Pinion Angle - In The Garage with CarParts.com
Whatever angle the u-joints work out to be, will always be the same on both ends of the driveshaft.
Notice that ∠ A = ∠ B
Old Jan 16, 2026 | 08:20 AM
LesMyer's Avatar
https://jagsthatrun.com/products/ult...t-1-hight-copy
You may have to shim the rear axle and install a spacer under the trans mount to do it right. Measure the angles with vehicle sitting squarely on the ground. Good luck
Old Jan 20, 2026 | 03:18 AM
I took my 86 K5 up 3" in the front - accidentally - when I bought new springs and forgot that what I was seeing and measuring was a badly sagged inverse ellipse spring and a set of snow plow helpers that had finally cracked and were flopping around inside the clamps ... but it looked bad. ... ya know?
So, I got the new springs in and needed to do something with the rears ... so I got some 2" blocks and shoved them in between the housing flange with the taper they sent and the new springs.
Everything went well after fighting with the rear spring company and telling them they were full of bull ka-ka telling me to angle to pinon toward the output of the transfer case. My mirrors were fuzzed up so badly they were useless.
I got it all set up --- but then the rear brakes started a new problem that I had to fix fast! Nothing wrong with the brakes --- they were working well.
If I braked very softly, no problem --- but use more brakes and there was a horrible flip-flopping on the rear u-joint.
So --- I waited for a couple of weeks to let the problem diagnose itself in my giant brain - and after a 2AM epiphany, I knew what I was gonna do --- and this is the video that I made.
Now hear me good here --- I am NOT a professional videographer and I can't edit videos --- don't know how.
So--- here you get a raw-ish video with good info ... truly fruit of my looms ..............
You might notice (as I did) that this video ends rather abruptly --- my bad.
Check the next post by me --- I'll try to get the 2nd half up there now ....
Old Jan 20, 2026 | 03:31 AM
Here's the 2nd half like I said ... again .... my bad ... I'm old, don't hurt me.
EdgarCervantes
Lowering Tech
Jul 13, 2012 01:38 PM
beto1
Nov 10, 2011 11:04 AM
YONKES
Lowering Tech
Jul 3, 2010 03:22 AM
Irobinson88
Lowering Tech
Mar 20, 2008 12:29 PM
EuroGoldLS
Lowering Tech
Jul 21, 2007 12:06 AM
